Hey guys in need of some advice.
I have an LOC Converter installed in the back of my Ford Focus with SYNC.
Factory Amp > LOC > Aftermarket Amp > Subwoofer
LOC. 12v constant is running to the amp power input with the power wire from the battery, the ground wire is tapped in the same to the amp, the REM wire is running from the LOC to the aftermarket amp.
Everything works and sounds great but I can’t figure out why the amp is staying on while the vehicle is off.
If I pull the REM from the amp it will turn off.
I’m not sure what my options are to fix this problem I guess that’s why I’m here.
I’ll check back often, thanks in advance.
