Line out converter problem
  • 1
hebertj12
Well I have a 2012 Honda Civic. I have one SPL 12" sub in a bandpass box powered by a rockford p300-1 amplifier. I have the factory radio so I used a PAC SOEM-T line out converter. I believe I installed it correctly because it all works. My only problem is that when I turn my car off the subwoofer keeps at a constant boom until I turn the car back on. What could be causing this? I'm new at using a line out converter so any advice to what the problem is would be very helpful.
The correct answer is yes, you want both left and right so you get low end information from both channels. It is very common for recording...
  • Locked
Cerwin Vega IOEM8 8ch line converter for sale, bought brand new as A-stock last summer. Mounted to baffle in preparation for installation but...
Update. Took line out back and just upgraded my head unit. Now my sound only plays when fade is in rear and balance to left. Ugh. One thing after...
20
3K
How did you tap your existing wires? I don’t trust Posi-Taps or anything similar for the long haul. If you used them, try removing them and...
8
hebertj12
hebertj12
Gueydan, LA
hebertj12
winkychevelle
    May 24, 2024
1aespinoza
    May 23, 2024
