I Like Waffle
Banned
X2. If you cant tell what he means by seeing the clutch engage, just listen to the engine idle, if it drops a little, youre good //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gifthe only reason a heater control valve would make ac not work is if it was open all the time letting hot water into the core. to see if your ac works or not, you need to start the car, turn on the ac and watch the compressor to see if the clutch engages. if it does, then the only thing preventing refrigerant from getting to the interior would be a plugged orifice tube.
