Large hole grommets
  • 7
I plan on 2 runs of 0ga and the grommet I'm currently using barely fits my single run of 2ga... What's the best way to get the wire through the firewall? Drill holes and get grommets for them?
Just for examples sake regarding electrical, I have 1400 watts total between both my amps and my system has no trouble running everything max...
27
You're not going to know until you test with a meter. Typically even carpeting a box as opposed to painting is going to lose a few tenths.
This will be an interesting issue to find out. Subscribed!! Are you running components? Ive had some caps blow in Passive xovers and a little...
983
I have dealt with several blow through sub setups over the years. Forget just trying to extend the port into the cab. All that you will hear in...
You're probably right. I have two Taramps smart 3 amps and four 10 inch CT sounds tropo for bass. I'm actually going to only install one of the...
14
ChaseinBass
ChaseinBass
Calif
jrdnhsnbrg
