JVC KW-DB95BT
  • 4
Cableman
10
Norway
Hi
someone here to do the update, this main unit with a flash usb downloads the files I need before update and save in the usb flash and follow all the information, when you go for steps of f/m to the update, says the main unit there is no file then
eny ideas what
Translation:
Hi
Get someone here to do the update, this headunit with a flash usb downloads the files I need before update and stored in the usb flash, and follow all the information, when you go step by step f/m to the update, the headunit says there is no file then
any ideas what its wrong
Hei
noen her for å gjøre oppdateringen, denne hovedenheten med en flash-usb laster ned filene jeg trenger før oppdatering og lagrer i usb-flashen og følger all informasjonen, når du går for trinn på f/m til oppdateringen, sier hovedenheten det er ingen fil da
eny ideer ho i can do
Google do it translate what ever i do
Hi, if no one here is able to help you figure it out, try over at diyaudio in the car audio section, it is a more technical forum. This is one of...
Usually when you shop for a replacement harness for your model, you will find the pictures may show you in what pins your wires go to.
Yes, the power wires' colors don't match from the dash to the new harness. However, I tested them and the wire I'm treating as the constant 12v is...
Its a Hit or Miss on FB.Market Place for buying any electronics. Pull it and wire it up at the vehicles 12v battery to see if it powers on...
Cableman
Cableman
Norway
Cableman
