JVC KD-R538 can't read USB WAV files
  • 1
ALind
Recently purchased this JVC unit - picked this model with intention of using the USB port to play WAV files.
When I insert a USB stick that contains WAV files the unit tries to read, then displays message - "CANNOT PLAY"
Is there an unpublished requirement for the format of the USB files on the stick???
Hi, if no one here is able to help you figure it out, try over at diyaudio in the car audio section, it is a more technical forum. This is one of...
Usually when you shop for a replacement harness for your model, you will find the pictures may show you in what pins your wires go to.
Yes, the power wires' colors don't match from the dash to the new harness. However, I tested them and the wire I'm treating as the constant 12v is...
9
ALind
ALind
Atlanta, GA
ALind
SPLBassJunkie
    May 21, 2024
Mr FaceCaser
    May 20, 2024
