JVC KD-G820 for a 10" D4 sub.
  • 2
WashYourWinky
The Pilot
Just picked up another head unit and would like to try and trade this one for a 10" D4 sub or a 12" D4 sub. Something that can handle around 600-800w rms.
JVC KD-G820
Comes with wire harness, trim ring, install cage, remote (needs battery), face case, and Ipod interface.
Cosmetic 9/10 Mechanical 10/10
CD player with built-in MOSFET amplifier (20 watts RMS/50 peak x 4 channels)
plays CDs, CD-Rs, and CD-RWs (including discs loaded with MP3 and WMA files)
Intelligent Equalizer (iEQ) — offers 12 adjustable tone presets and a 3-band EQ
front panel USB input for MP3/WMA playback
detachable faceplate with a variable-color, 3D graphics display
Personalized Image Capture Technology (PICT) software for loading your own images and animations for the display
loudness
three sets of preamp outputs
subwoofer level and frequency control
CEA-2006 compliant amplifier
controls for an optional JVC iPod adapter
SIRIUS or XM satellite radio-ready (SIRIUS or XM Tuner, antenna and subscription required to receive satellite signal)
HS-IV AM/FM tuner
18 FM/6 AM presets
seek tuning
clock
remote
CD frequency response: 5-20,000 Hz
CD signal-to-noise ratio: 98 dB
FM sensitivity: 11.3 dBf
Hi, if no one here is able to help you figure it out, try over at diyaudio in the car audio section, it is a more technical forum. This is one of...
Usually when you shop for a replacement harness for your model, you will find the pictures may show you in what pins your wires go to.
Yes, the power wires' colors don't match from the dash to the new harness. However, I tested them and the wire I'm treating as the constant 12v is...
9
Its a Hit or Miss on FB.Market Place for buying any electronics. Pull it and wire it up at the vehicles 12v battery to see if it powers on...
969
WashYourWinky
The Pilot
WashYourWinky
Cincinnati, Ohio
WashYourWinky
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
