JVC Double DIN KW-AVX840, replacing JVC start-up logo
I'm not sure how, but I assume you would plug a flash drive with your image on it into the USB dongle of the jvc unit. I just got the jvc kwav71bt, and would really like not to see that really bright annoying JVC logo. A blue dors emblem would be just the ticket. After plugging in your flash drive, go to settings,display,screen design, and capture. Just a guess but I just watched a YouTube video about it. Let me know if you find out for sure. All this computer stuffs kinda over my head, but if that works for you, I can get my daughter to show me what to do on the computer.
If it can be changed easily, then it would be similar to the Kenwoods since, like HangFire pointed out, they are the same company.
Other than that you would have to have an extensive programming background. You would have to have software to write custom code to flash over the boot sector on the HU.
Google do it translate what ever i do
4
307
Hi, if no one here is able to help you figure it out, try over at diyaudio in the car audio section, it is a more technical forum. This is one of...
Usually when you shop for a replacement harness for your model, you will find the pictures may show you in what pins your wires go to.
Yes, the power wires' colors don't match from the dash to the new harness. However, I tested them and the wire I'm treating as the constant 12v is...
9
trussard
trussard
CA
fatboytyler
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
