JVC Bluetooth Dongle?
  • 2
jco1385
expert jcologist
19,957
Mobile, AL
I have a JVC KD-S88BT that I am about to install. I did not realize until right now that there is a 'dongle' for the BT function. I don't have it, and JVC wants $50+ for it. Can I just get a cheapo BT dongle on eBay, or is this a JVC specific item? Does anyone here have one that I can buy? Is it 2.0, 3.0, 4.0? //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
JVC item number is QAU0526-001 -> LINK
Any insight is appreciated.
The Part# QAU0526-001 also known as KS-UBT1 is a Bluetooth 2.0 adapter with the Cambridge Silicon Radio chipset. I am not sure if a generic BT module with the same chipset would work as this one may have specific hardware/software ID's that are recognized by the head unit. I'd be curious to know if you're able to get this to work as I also have a bad BT adapter.
Google do it translate what ever i do
4
383
Hi, if no one here is able to help you figure it out, try over at diyaudio in the car audio section, it is a more technical forum. This is one of...
Usually when you shop for a replacement harness for your model, you will find the pictures may show you in what pins your wires go to.
Yes, the power wires' colors don't match from the dash to the new harness. However, I tested them and the wire I'm treating as the constant 12v is...
9
jco1385
expert jcologist
jco1385
Mobile, AL
mccollumsp
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
