Jeep Patriot Build "Input needed"
  • 4
kumar_numar
I am a working man looking for some inputs on my future system. I have some one the parts already and working on buying the rest later.
I cant get a HO Alt. The only one I found was a 165 amp. Stock is 115 amp
Bold = Already have
The build
Amps
Rockford Fosgate P600X4
Sundown SCV-3000D
Rockford Fosgate Punch P1T-S Tweeter Kit X2
Rockford Fosgate Punch P1692 X4
Power
Run front to back X 2
XS Power D3400
XS Power D1200
XS Power D3400 X 2
PSI P2 15" X 2
Radio
Sony MEX-XB100BT
I am a working man looking for some inputs on my future system. I have some one the parts already and working on buying the rest later.I cant get a HO Alt. The only one I found was a 165 amp. Stock is 115 amp
Bold = Already have
The build
Amps
Sundown SCV-3000D
Power
XS Power D3400
XS Power D1200
XS Power D3400 X 2
PSI P2 15" X 2
Radio
Sony MEX-XB100BT
Ok first off. What is your over all goal? Sound quality? Get loud as possible? Why have you chosen the psi subs?
Have you figured out if you have room for the box that will hold 2 15s?
Lets get you out of this rockford thing. Its a brand name and way way too expensive. Look on this site. Everything on here is quality and far cheaper/better than rockford.
http://store.soundsolutionsaudio.com/
What are you using as a source(cds, ipod, phone) and how are you hooking it up to your system(bluetooth, wired, ect)
Sent from my SGH-T999 using Tapatalk
Looking to be loud as possible!
I have plenty of room for 2 15s.
I already have 4 of the 6x9s from rockford
What would you recommend for the tweeters and 4 channel amp?
I am using usb and my phone for music
Skar Audio RCAs
Precision Power PPI P900.4 Phantom 4-Channel Amplifier
Solid 4 channel that has average sound quality ^
if you want better sound quality but less power. Go with this
SSA Store - US Acoustics Barbara Ann 4 channel amplifier
Why do you want tweeters? your 6x9s have built in tweeters.
these are EXCELLENT subwoofers. They get plenty loud and have phenomenal sound quality. Very accurate subs. If you are leaning more towards getting loud as possible without much regard for sound quality. You are going to want a high excursion subwoofer. Sundown makes excellent ones but they are pricey. Might want to look around on here for good deals. Caraudio.com IS the SPL crowd. Im sure someone can give you a hookup for custom SPL subs in your price range.
ICON 15 Sound Solutions Audio 15" 1250W ICON Series Subwoofer - SSA STORE
i dont think your going to need 4 batteries for 3k rms. @adulbrich
Who is building your box/ where are you getting it? The box is JUST as important as the subwoofer.
I go camping a lot and use my lights and radio for hours without my car running.
I am building the box my self. I have a lot of tools and a table saw.
Using this website to help calculate the box
Subwoofer Enclosure Calculators, Parallel, Series, Port Length and Volume
Thanks for your input so far:D
Make sure you add a lot of bracing, maybe even fiberglass the inside for smoother corners. Post your dimensions on a separate thread and get some input. If you go camping alot. Look into getting a solar panel. Might be a cool idea.
Don't plan to run your system too long with that battery bank and the car off. That's a small alternator too, and you might have bad drop with 3k and the car running.
Don't get the Rockford's, PSI's, or the Sony radio
The gear in bold he already has :/
I am not running the sub without the car running. Just using the door speakers and lights. I have battery chargers at the house and planning on buy some xs power chargers later
Alright, he had the radio. Didn't have the Rockford speakers/tweeters or amp though
Ok, that's fine then
Be sure to see the sub specs. It should tell you the ideal sealed enclosure size.
600
TBH, that is too many speakers for just a pair of 10" subs. The Skar 6.5s and tweeters are very efficient and can get super loud on moderate...
923
I purchased a set of 1" stand off rings, should still be good from door to cone as well. They won't fit without the spacers, the recoils I...
30
8K
It is the same one that Rockford Fosgate sells as well. They are identical and the NVX is cheaper as well. Even Amazon has them iirc for 199.99...
Is anyone familiar with, or can help with the Infinity system (with amp) fitted in 2001 Jeep Grand Cherokee? I've installed a Atoto A6 head unit...
kumar_numar
kumar_numar
Nashville, TN
kumar_numar
    May 31, 2024
    May 24, 2024
