Jeep door pods build
here to buy
Crescendo
1,472
Florida
hi
im going to take the time and make a log for my first solo fiberglass build, its my first time glassing without help of a shop pro. i've helped out with glassing around the local shop, but just laying down mat and punching it with resin, so thats the bulk of my own glassing experience lol, UNTIL NOW!!
its for 2 Mpyre 7" mids per door.
anyways, here are pics, finished this passenger side pod buildup 2 days ago
cutting up virgin doors
put plastic epoxy down, than resined over it quick and matted the area up, creating a stiff backside enclosure that'll be fully sealed when everything is done.
after last layer of mat (2-4 layers all around)
there is a whopping 30 oz of resin on this pod!!!!!
cutting out holes, test fit mids
trimmed a lil
angle
my friend will be doing the sanding and finishing work on them,
That looks like a LOT of resin on there in the last pic. Have fun with sanding/body filling //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
today i started the drivers side pod, just fleeced the pod shape
heres pics,
hot glue is where its at!
i screwed up a lil around here and had to cut and seam to avoid a big overlapped crease
i now hate fleece, wont be using it anymore myself in the future, should of borrowed some of this lycra material they use at the shop
Rabbet an edge into the outside of the baffle... staple the fleece into that edge... then after the resin starts to gel slice if off right above the edge.
Then you have a clean baffle to mount to. //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
Nice mids //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
nG
nG
yeah i know thats wut i should of done, but i didnt, and so now the baffle needs to be sanded to be plane leveled all around, thats gonna **** //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
yeah the mids are sick! i had two in my doors and they could play near sub duty!
Shouldn't have made them sealed, thats way to small for 2 7s.
obviously the airspace is not ideal, but it is larger than it looks in the pics, the cutout map pocket is recessed into the jeep doors deep, so the pods are around 9-10 inches deep
Be sure to see the sub specs. It should tell you the ideal sealed enclosure size.
674
TBH, that is too many speakers for just a pair of 10" subs. The Skar 6.5s and tweeters are very efficient and can get super loud on moderate...
985
I purchased a set of 1" stand off rings, should still be good from door to cone as well. They won't fit without the spacers, the recoils I...
30
9K
It is the same one that Rockford Fosgate sells as well. They are identical and the NVX is cheaper as well. Even Amazon has them iirc for 199.99...
Is anyone familiar with, or can help with the Infinity system (with amp) fitted in 2001 Jeep Grand Cherokee? I've installed a Atoto A6 head unit...
here to buy
Crescendo
here to buy
Florida
Alpine4life89
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
