JBL Broken Basket - What are my options?
E-Rock
Bass of All Basses
479
Boise, ID
Haven't posted to cacom in awhile. Now that I'm not a broke college student (just broke) I decided to finally get around to doing an install in my F150. I've have a set of JBL MS-62c's that sat in my closet for a few years now.
While I was checking my mdf adapters for fit... let's just say that my mid got away from me. Dropped it right onto my garage floor. Pics are in the imgur link below.
https://imgur.com/a/jteHLFC
What are my options here? I'm almost at budget for this entire install. Getting a replacement JBL woofer is a longshot. Is it possible to JB Weld it back together? There is another crack that I am worried about. Or should I just find another 2 replacement woofers from another company (Dayton, Madisound, Crescendo, etc.)?
I was going to run these passive and from my understanding is that JBL uses a 3-3.5k crossover point. I could really use any help possible and am open to any suggestions. Delays stink, but I just want to get this system up and running. Amp is a RF Prime 4 channel bridged for 150x2, not likely to see all that power though. I really hate myself right now considering how excited I was to finally use this beautiful set that I have only heard positive things about, only to break it for trying to work at night.
Afterthought, would my speaker still work fine if I were to mount it? There would be a gap between the surround and adapter, but since this isn't a sub and doesn't need a perfect seal would it work? Would it negatively affect SQ?
Any two part epoxy will work, like JB Weld that you mentioned. Should have no problem repairing. Just take your time and do it right. Don't slather it on and get it everywhere and make sure it's fully cured, usually atleast 24 hours, before using.
Thanks Slo! I have the JB Weld curing right now. reattached the broken part of the ring and put a small amount on cracks near the screw holes. This definitely helped put my mind at ease.
I recieved a zcon 15 in the mail with a cracked basket in 2 or 3 spots. I used some dp420 epoxy on the cracks and its still holding together just fine after probably atleast a year.
The epoxy is holding up really well. There is a slight bend on the mounting ring where is broke off but has a minimal impact on fit and shouldn't matter once a gasket is made on the mdf.
It will probably be a few more days until the speakers are mounted in the door. Once that is done and they have some play time I'll update the thread. Can't believe I was about to buy some replacement woofers over a $4 kit of JB Weld!
Thanks guys!
I didn't see where there was a difference (didn't see a "light" or "lite" version). That said, if you can fit it, then the JBL BassPro SL 2 would...
WANTED JBL 800GTI
Slava Ukraini, Brother! Don't have that amp but good luck and welcome!
I don't think this is ideal, but let's assume you can easily mount all the tweeters. That installing them is going to be really simple, and...
13
Working with undersized material, adjusting on the fly, testing before setting; you sound like and old pro. You are as meticulous as alot of the...
76
6K
E-Rock
Bass of All Basses
E-Rock
Boise, ID
E-Rock
maylar
    Jun 2, 2024
    Jun 1, 2024
