(Issues)Sundown zv3 12 D2
Pavelpardo
Sundown zv3 12 D2
The sub plays fine at all levels of music but it gets a tick/ cool rub noise at high excursions only. (Low notes) //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
200 plus shipping OBO. I an willing to haggle on the price quite a bit if should before 8/21/15
Will split with buyer
No it was purchased brand new A stock but after a comp day the weird noise began to show. Possibly due to it being In a big box 4.5 ft^3 at 1800 rms
A 12 in 4.5cf? I'd say you're bottoming it out at lower frequencies. That's the noise you're hearing. If it hasn't been damaged by the coil being bottomed out, it probably plays fine in a proper enclosure size.
Same thing i told the guy who "designed" and built the box for me but he said it was built to spec after woofer, port, and bracing displacement. I knew i shouldnt have trusted him when i pulled up to his "shop" garage to see only a jigsaw and tape measure. Live and learn I guess... BUMP NEED THIS GONE THIS WEEKEND BEFORE I MOVE
Be sure to see the sub specs. It should tell you the ideal sealed enclosure size.
594
Twist both grounds together. Good call on checking power with a multimeter. I assume you have pulled out and re-inserted the fuses, so as a quick...
Are your tweeters amplified or powered by the radio or maybe factory amp? I'd check your wiring for sure, make sure 12v power and ground are...
Pavelpardo
Pavelpardo
Rupert, ID
Pavelpardo
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
