iso kicker 15s in tube
  • 3
im building this box/tube to go in the trunk of a Honda with the ports going thru the arm rest in the back seat. So my ? is can i run the port tubs on the out side of the box like in the pics?
The triangle on the front will be the amp rack. the tubes on the back will be the ports that will go thru ur back seat. The 2 kicker 15s will be in the big tube.
im about to start this box anyone see any problems with it?
i was thinking of doing slot ports and use the out side of the box/tube as part of the port. So if the port needs to be 12x1.5x25 how do i build the port do i make the port wall 90 deg off the tube or do i slant it to curve of the box/tube? or do i stick with round ports?
Just a thought but I might run a 4" or 6" pvc port and that would fix your slot port problems //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
so if i use the round ports can i put some of it in the box and run it out do a 90 then run it down the outside and then another 90 thru the back seat or is that to may bends
well with a lot of googling and a few replies here i come to the point that i will do slot ports that start in the box come to the out side, use the outside of the box as part of the port and then end up in the back seat arm rest. will look like this some what
  • Locked
COMPLETED ISO- AQ3500D.1
I know probably a long shot but I’m searching for an AQ3500D.1 it’s an older amp previously called Audioque, that was bought out by soundcubed. If...
3K
Dave Leib Corey Dean (SPL Audio) https://directronix.net/product/customzvx/
claycity
claycity
United States
claycity
