Is this amp good??? Let me know what you think!
  • 3
All three of those amps are of good quality and from reputable companies. If you are running below one ohm I would probably go with the sundown or the aq and make sure you have the electrical to back them. Any of these should be plenty of power for what you are running. As for which one is best that is really up to you. You will have ten people telling you brand x amp is the best and at the same time have ten people telling you brand y is the best . Its more about what is going to work and sound best for you.
193
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
389
6
487
  • Locked
NVX MVPA1 Best tiny amp Installed a bunch, but have one pushing a sealed 12 @ 2ohm in my daily beater Can bump it all day long and barely gets...
4
779
Amp
This tested well on youtube - not familiar with the brand but it is a pretty standard china build house amplifier...
5
562
MrKapone
MrKapone
Austin,Texas
Spooney
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
