Inverter noise? What can be done?
  • 2
Melvinl
Hei Guys!
I am basically building a party rig in the back of a van and i need some help.
I have 2x 140ah batteries in parallel connection giving me 280 Ah max.
from that i am running:
2x12 dual Comp S Kicker running from Pioneer GM-D9601
2x12 dual Comp S Kicker running from Kicker 12CX600.1
4x Kappa 62.11i Infinity by Harman running from an Kenwood KAC-6405 4 ch (i think, 80% sure)
On top of that i have an 1000W inverter that i am running a small smoke machine, strobe light and lasers from.
Problem is, inverter makes a great amount of noise in the speakers when in use. Is there anyway to reduce / remove this?
12v Noise filter?
Capacitor?
In that case, any specific ?
Any respond is helpful! //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
The first thing I would try would be the capacitor only because it will be cheaper than a commercial filter. Radioshack should have at least a few to pick from. Get the biggest capacitance cap you can find that has at least a 14V rating (higher is fine) and put it in parallel as close to that inverter as possible.
You just found your own solution. Move the DSP elsewhere. The RCA is triple protected but not the RCA plugs. I do not know if there is a mesh or...
Yes i know that's what i was planning on. Unfortunately the rvca's are a little difficult to gain access to. My other thought was to wrap a wire...
Melvinl
Melvinl
Norway Halden
bubbagumper6
