In need of a Sub box design please
  • 1
SethPhillips
I'sa Playa
so i need a box design from one of ya if I could.
I'd like the box to be braced, and port on one side the box is going in a honda accord.
Trunk MAX Dementions are: 28 1/2'' Wide X 32 1/2'' Deep X 15'' High.
Power Handling
(RMS/Peak): 400/800 watts
Nominal Impedance: Dual 4-ohm
Voice Coil Size: 2 in
Frequency Response: 24Hz - 450Hz
Sensitivity: 92dB
Motor Structure: 180 oz
Mounting Depth: 6.0 in
T/S Parameters
VC Impedance: 4 ohm + 4 ohm
Test Impedance: 1.6 ohms
Fs: 23.16 Hz
SD: 514.72 sqCM
Vas: 120.67 Ltr
Cms: 320.75 µM/N
Mms: 147.25 g
BL™: 7.32
Qms: 2.48
Qes: 0.64
Qts: 0.509
No: 0.227%
Spl: 92 dB
Xmax: 9.5 mm
let me know asap
A pair of American Bass Hawk 15s will slamm home as well. Just put in a pair in a good friends 02 T.Car in 7.0@31htz on a Cresendo Skyway 3k...
29
People didn't like ported boxes because the port noise and needing a bigger box. Therefore, instead of 1-sub in a ported, they would go with...
30
3K
I'd be willing to pay for a quality HU, if it meant that I can truly get the sound quality I need. I've seen some aftermarket ones that look...
10
932
* The fuse at the start of the cable needs to be equal to or greater than the fuse/load at the end of the run. * The cable needs to be capable of...
4
Thank you for your reply. What if I wire in series for 8 ohm load ? Sorry for my newbie questions, but wouldn't it have better sound quality...
SethPhillips
I'sa Playa
SethPhillips
Northern Utah
SethPhillips
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
