ID8 v3 testing enclosures
  • 1
mat3833
373
florida
ok, so i got my 2 ID8 v3s and im going to do a review on them for you guys. only problem is i only have enough wood to build 3 enclosures and i need 2 of those for the enclosures they will reside in for the forseeable future. so i have come to a compramise:
im going to build the 2 enclosures for my home theater but tune them higher (say 25-28 hz, not sure yet) and use one of them for a "sq ported" settup deal. then i will make the third box ported as well(probobly 32hz or so) with a removable front so that i can block the port and run it as sealed too.
the only problem im having is deciding on what the total volume should be for each enclosure. for my HT enclosures i have ~2.8 cubes for each sub. and for the last one i dont really have limits i guess.(it will be in my buddys lincoln town car you can fit like 8 bodies in that thing...) i was thinking of having the 32hz box have an external port so that i can do a "SPL" box as well since i have the feeling that these little guys can get pretty **** loud.
anyways, what would you guys prefer as far as testing boxes? Discuss
Matt
THIS IS THE SAME AS THIS: One coil + to the other coil - (on each). The other + & - to the terminal block. Terminal blocks wired straight...
i see, good to know At least. that means i could squeeze out more air volume indeed. bit of a crude design but so far was thinking of roughly...
Yeah. Same thing here. The under seat box I did for the 8s was 325$. He’d already wasted that much with 2 prefabs that sounded like ass.
6
You can run the SVC subs on the GM-DX871 at 1 Ohm, just lower the gain at the amp. The third sub is too different to run on the same amp as the...
mat3833
mat3833
florida
mat3833
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
