IB Help...
  • 3
reible82nd
Hey everyone,
Just got done putting a wall in my trunk and running my PPI A.8SQs IB, it sounds good but I have few questions. I mocked up the wall **** near perfect so it's pretty sealed, it sounds good but seems to sound a bit "choked out." I'm also running a pair of 6x9s in the back dash too, so they're running IB in the trunk as well. With everything sealed off, am I supposed to "port" the trunk somehow? If so, how do I calculate the diameter and length of the port? I've attached some pics to bring everyone up to speed. Any advice would be greatly appreciated, thanks!
View attachment 26535212View attachment 26535211
you miss the point of IB. it's not sealed if you have speakers back there. you need to build enclosures around the rear speakers, or remove them and seal off the opening. those speaker cones are near invisible to bass frequencies, so bass travels right through the rear speakers, causing a lot of cancellation.
you cannot run rear deck speakers with "IB" subs.
adding a port would further defeat the purpose. you want to fully isolate - meaning air tight/water tight - the trunk from the cabin. anything that flexes (speaker cones) is cancellation. you cannot have too much mass separating the trunk from cabin. i have about 5 layers of deadening on my rear deck and 3/4" MDF closing off the rear holes. see my build log for how i put an IB wall in.
further, you are not sealed to the metal, you are "sealed" to the carpet panels. bass travels right round/through the factory carpet and leaks around the sides - causing more cancellation.
you'd be better off putting a box around the back of that board.
Thank you for not totally destroying me man, that was quite professional. I don't have any experience with IB stuff, clearly this was a feeble attempt at setting one up and I failed. I probably should've done more research before trying to tackle this...I like the wall though, maybe I will just enclose the subs in the trunk and leave the wall there. Thanks again.
Plus those weren't made for i.b.either...if your going to use those an enclosure is king..
If you want to go i.b. Look at 12-15s...cone area is best for that...i did 2-10s in the rear deck of my altima and liked it..im kinda a bass head though..
I was going to buy those 18s we talked about...thought they may be too sloppy for me..
Got it figured out! Thankfully a friend just found out about KunKonceptz UBT-20 terminal adapters that allow multiple connections to my type 94...
531
Turn the volume completely down and operate ot normally. This is to see if it is the built in amplifier that is shutting down. If the radio does...
That would be a function of the harness, not the HU, I think. Have you looked into a Maestro or iData interface? i would check with crutchfield...
12
553
I went with Kenwood Exelon. Audio Control amp and speakers. It’s amazing! I’m glad I did some research before buying. Thanks guys.
5
622
reible82nd
reible82nd
Lillington, NC
pickup1
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
