I need help please !
  • 3
Juss64
Hi guys, I'm new to subwoofers and I have difficulties to understand how it is working.. I want to buy the Rockford Fosgate RFP4212 subwoofer (single one not dual) and put in in a box. I was looking for what RMS wattage should I take for my ampli and wires ! Can someone help please ?
Thank you !
Justin
Thank you !
Justin
Im not understanding your question
Thank you !
Justin
That model number doesnt pull up on google for me.???
Looks like by specs, you need a minimum of 100 watts rms up to 400 watts rms @ a 2ohm stable load to run that sub woofer,due to being a DVC 4 ohm sub..Lots of choices out there for this type of power buying new or used.What vehicle is this going in?
Nissan Versa 2009 HatchBack! I found a used Alpine MRP-M500.. would it be enough for the speaker I want to buy ?
So you're planning on running active and using the amp or head unit crossover for the tweeters? Is that sub channel full range and have separate...
981
Or you can buy a bypass https://lljcustoms.com/products/2018-2021-gm-gmc-factory-anc-bypass-select-vehicles
4
976
Lifelong Pioneer Premier series user here. Switched to the Kenwood eXcelon Reference (XR) DDX9905S and never looked back. Excellent sounding...
9
457
Juss64
Juss64
Quebec, CAN
audiobaun
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
