I am a newb, HELP!
jonesound
So one of my good friends is a big bass head, and I asked him to help me out with my first system. He told me to get this:
1) MB Quart ONX1.1000D (1000W RMS ONYX Series Class D Monoblock Amplifier (ONX-1.1000D)
2) Alpine SWR-1522D 15" Dual 2 ohm Type-R Series Car Subwoofer
3) Ground Shaker SQPXL 1 15 15" Single Slot Ported/Vented Extra Large Pro Subwoofer Enclosure
4) RE Audio WK-4A 4 AWG Complete Amplifier Installation Kit
I have a 2009 chevy cobalt lt 4 door.
All I am asking is if this will work good? and tips? or forums i should read to help me out. I appreciate the help.
He really didn't steer you wrong. That's not a horrible starter system to bang with and learn from. Switch out the wire kit for an ofc 4ga kit from Audio Technix or knukonceptz. Both are on ebay.
You have a link to the box? Prefabs aren't ideal, but SOME will do ok for a beginner that isn't interested in building one from plans.
Your friends suggestions aren't too bad. I agree with everyone on the box though. Get a good one made or make one yourself. Prefab boxes are usually too small and tuned to high. You're going to want that Alpine in around 3.0-4.0 cubes tuned at 32-36 or so. This is the one that you're looking at I think: http://www.sonicelectronix.com/item_62694_Ground-Shaker-SQPXL-1-15.html It doesn't look too bad for 100 bucks. It's at least 3/4" MDF and big enough. But with a sub that weighs around 45 pounds you're going to want the front baffle at 1 1/2" and who knows what it's tuned to?
They should work. I have 6.5s in my lower door to replace the 8" subs that came with my mustang. They are fantastic, and outperform the 6 x 8s...
I would add an ANL Fuse @the amplifier supply with its recommended 100 ANL fuse, and Keep the 120-150 @the Battery...
6
You may or may not like the sound of just dropping into the stock locations but loading into the glass is definitely going to cause some issues...
15
3K
Got it figured out! Thankfully a friend just found out about KunKonceptz UBT-20 terminal adapters that allow multiple connections to my type 94...
413
Turn the volume completely down and operate ot normally. This is to see if it is the built in amplifier that is shutting down. If the radio does...
jonesound
jonesound
Los Angeles, CA
AcuraTL03
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
