How to wire mono block amp to 2 subs?
kinda curious.
why do some mono sub amps have a pair of ++ and - -?
im assuming its just opening up for more surface area?
and more wires to each terminal?
might wanna wire it like this:
Well your amp can do 1700 watts at 2 ohms or 1200 watts at 4 ohms.
You can wire each sub's voice coils in parallel and then wire the subs together in series to get a 2 ohm load to your amplifier. You could also wire each sub's voice coils in series and then wire the subs together in series again to get an 8 ohm load. I think those are the only two options you really have with this amp, but it depends on the power handling of your subs really. Anyone feel free to correct me if I am wrong.
Check this out for help with your wiring.
http://www.crutchfield.com/S-8t7JJCcy9Bp/learn/learningcenter/car/subwoofers_wiring.html
Edit: Didn't see it had been answered already. What he said pretty much.
This is what I ordered from Amazon. https://www.amazon.com/gp/product/B07MXMPHKS/?tag=caraudiocom-20...
5
369
the AVIC was a tad more complicated to wire not to mention stuffing it in a smallish stereo hole. thanks for advice.
8
859
Drill a hole and use the proper protective split loom and hole grommets to keep the outer speaker jacket from knicks and cuts, give just enough...
8
990
It mostly comes down to weight. You can have a super lightweight cone, soft suspension and aluminum coil on a sub and you pretty much get a pro...
4
987
fastball11
fastball11
Greenville, SC
scoob8000
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
