How to wire 4 svc 6.5 door speakers to a 4 channel amp
  • 5
Yes.. One speaker to each Channel for 4 ohms. You can also wire Two together for a 2 ohm load having 2 on two channels freeing up the other two channels to use for other speakers if youd like and other configurations. Get a manual and go by the information provided to properly wire that amp correctly towards stability
This is what I ordered from Amazon. https://www.amazon.com/gp/product/B07MXMPHKS/?tag=caraudiocom-20...
123
the AVIC was a tad more complicated to wire not to mention stuffing it in a smallish stereo hole. thanks for advice.
626
Drill a hole and use the proper protective split loom and hole grommets to keep the outer speaker jacket from knicks and cuts, give just enough...
919
It mostly comes down to weight. You can have a super lightweight cone, soft suspension and aluminum coil on a sub and you pretty much get a pro...
892
Ufc_fan918
Ufc_fan918
Tulsa
SilverSquared
audiobaun
    May 19, 2024
    May 19, 2024
