How to wire 4 infinity kappa 62.9i with Alipne MRX-v70 at 2ohm load ?
  • 3
zeshan105
15
Newyork
The amp is 5 channel and I want to wire every speaker at their respective channel. How do I wire that to make all the speakers run at 2 ohm load ?
The speakers I have are infinity kappa 62.9i in front doors and back deck. The speakers are single coil.
You'll need 4 more speakers....unless they are 2 ohm already.they are probably 4 ohm...so you need 2-4 ohm speakers wired In parallel to get a 2 ohm load.
Is there any way to test ohm load of speakers ? or how many watts are going from amp to one speaker ?
Component sets are complicated because of the crossover. You can get a ballpark idea by measuring the resistance of the woofer's voice coil with an ohmmeter. Infinity says they are 2 ohms but the extra resistance of the car wiring will bring them to 4 ohms. That's marketing BS.
Measuring the actual power is not a simple task. In the end, it doesn't really matter ... a few watts either way is insignificant.
This is what I ordered from Amazon. https://www.amazon.com/gp/product/B07MXMPHKS/?tag=caraudiocom-20...
5
413
the AVIC was a tad more complicated to wire not to mention stuffing it in a smallish stereo hole. thanks for advice.
8
902
Drill a hole and use the proper protective split loom and hole grommets to keep the outer speaker jacket from knicks and cuts, give just enough...
8
It mostly comes down to weight. You can have a super lightweight cone, soft suspension and aluminum coil on a sub and you pretty much get a pro...
4
zeshan105
zeshan105
Newyork
maylar
