How to tune for specific frequency?
  • 2
MDH69
CarAudio.com Newbie
11
Kansas
Im wanting to use some Qpower shallow sealed sub boxes ....Manufacturer states they are .51cubic feet.
If i wanted to port them and tune to say 40hz ,what size port diameter and length would i need to get in that area?
You need to know your net airspace and the surface area of the whole port. I would tune lower
It has no ports at all...not sure where to begin with it all...3 inch tube 4 inches long?..2 inch port 3 inches long?..Aside from box dimensions and advertised cubic feet i have no other specs.
If you're going to port a box, you need to build your own from scratch or have someone build it for you. Don't modify a already made sealed box into a ported one, it probably won't be proper airspace at all.
Youll need a Honda Civic reverse radio wiring harness and 20 toyota radio wiring harness ...match colors of wires and shes ready to go...
Check your grounds! Both head unit and amp. I had this issue before and it was a grounding issue. Ground wire made enough contact to play low...
dragon.breath, Many thanks for taking the time to help me out. It is very much appreciated and my small brain can understand it now. I have...
6
772
Do you know what the box/port tuning is? And what is the db/octave slop on the crossovers being used? Setting the amp crossovers as open as...
8
MDH69
CarAudio.com Newbie
MDH69
Kansas
Buck
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
