How To Test A Sub
Push up/down on the cone to see if the coil rubs.. be carefull because some subs have tight gaps and if you do not push exactly strait you may cause the coil to rub yourself..
T
ouch a 9V battery to the terminals and watch the cone pop if you don't have a DMM to check for continuity..
That is the perfect spot to do that. OEM sub may interfere with the new one and cause cancellation.
602
But then you could just use the volume knob to rather than pay for earplugs.
801
Slobra232
Slobra232
Phoenixville
406er
Decebal
    Jun 10, 2024
