How to set hpf and lpf on sa sfb 1000?
  • 3
MyNameIsHere
CarAudio.com Regular
117
4
USA
I can't figure out how to set the crossover on the amp.
30574
Right now they are all the way to the left. I just have to set gain.
The hpf isnt supposed to be all the way to the right?
No the HPF works as a subsonic filter. I forgot you don't have an aftermarket headunit so you will want to set the HPF depending on your box tuning.
say you are tuned to 45 Hz:
- 45 Hz / 2 = 22.5 Hz (one octave lower)
- 22.5 Hz /2 = 11.25 Hz (half an octave lower)
So we take 45 - 11.25 = 33.75 Hz (rounded up to 34 Hz)
In other words, you set your sub-sonic to 34 hz. So that way, if there's music below the ports frequency, it gets filtered out protecting your woofer.
Always remember the subsonic filter is NOT a cut-off. It has a roll off "slope" where whatever frequency its set to will be attenuated, and the attenuation effect increases as the frequencies get lower. Thus the power to the woofer decreases at filtered frequencies, which reduces the excursion and risk of damage.
My subs are sealed
6
324
Time alignment is used to delay every speaker closer than the furthest to have the sound hit the listeners ears at exactly the right time. If this...
8
741
You can get close with tones, but music signal is all OVER the place in both frequencies and voltages. Like, if you listen to rap, the bass line...
822
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
Send me all the items. Once I receive them, I will verify everything in your classifieds. If someone buys them, I will ship out. You would just...
MyNameIsHere
MyNameIsHere
USA
MyNameIsHere
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
