How to properly Launch Start...an A/T
RetroVetro
I have a 92 sentra, automatic transmission. My question is: What's the proper way to Launch?
N when u do launch start..is it really that for the tranny?
Im not sure if i've been doing it right, but, I've tried it a couple times. When im on this straight away in my subdivision, I stop, stomp on the break, rev up to 2500-3000RPMs then let go of the break. Is that the right way to do it? Am i doing it right?
Thanx
yes, just hold the brake down give it as much gas as you can with out moveing the car or spining the tires, then when the light turns green let off the brake and floor it
put it in nuetral then tach it out, then drop it down into first. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Dropping straight into 2nd or 3rd will give you a much better launch //content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
jk dont do that...
if you do the neutral/drive launch, you will destroy your tranny...period. Stock converters will only hold to a certain RPM, like most Chevy's, 1200-1500. But most racers use a larger stall, which get's you into the RPM range faster. I had a 3500 stall in my truck.
Proper way is to footbrake, like mentioned, and just get the car where it is ready to roll, then stomp...
But if you do this alot, your tranny, without the proper aftermarket cooler, will also destroy your tranny.
As you let it stip, and foot stall, tranny fluid rises quickly.
Lenco>glide>all //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
rocket car>Lenco>glide>all //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I have a jeep wrangler 2010 4 door.. So 2 of my speakers are in the dash upfront. And the other 2 are in the bar in the middle of the car
6
I have read about this, and honestly the installer did nothing wrong. It's the newer vehicles that have the automatic engine stop/start (instead...
Not with a Toyota but with a Dodge Stratus. The Security Key Immobilizer Module (SKIM) was activated and it would not energize the coils. Check if...
That's what I'm going to do, cheap, and easy to do. I picked up a spst switch today
I found a solution that you may try. PAC TR-4 Remote Turn on module. It's on Amazon for about $17.00
RetroVetro
RetroVetro
Neverneverland
cheeseburger35
Decebal
    Jun 10, 2024
