How to identify speakers with no id tags
  • 3
I have a lot of 8 in mid speakers with no manufacturer ladles on them have found writing on the inside of the cones and a few have a Barcode that doesn't scan back to any thing attached are a few pics of speakers and motors
Sent from my SM-G930T using Tapatalk
---------- Post added at 11:37 PM ---------- Previous post was at 11:36 PM ----------
First 3 subs are dvc 6.5 coils second set are svc 3.5 ohm
That's likely a lost cause unless you get super lucky and someone can ID them for you. //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif I'm assuming you tried searching all numbers/letters on the barcode in different ways?
Both versions look like speakers made by a company called "Credence Speakers".
They made these 6.5" in the early 90's, which has a magnet and pole vent like your first post.
They also made most of the early Kicker speakers and subs.
Unfortunately they went out of business sometime in 2013.
uhhh, yep. The bezel doesn't look automotive, and neither does the surrounding wood grain.
5
You probably did it already, but post this to 350z specific forums or facebook groups, etc. There's probably someone there that knows.
Might be ok to run in the garage in 4 ohm stereo on about 20-50 watts. It may run for quite a while that way?
4
764
mpedigo
mpedigo
Knoxville, Tn
Rich B
winkychevelle
    May 24, 2024
1aespinoza
    May 23, 2024
