How to fuse a dual input amplifier?
  • 3
Hi. I have a PPI DCX 1000.1. It has dual inputs for power and ground (2 from battery, 2 grounds). The fuse rating of the amp is 100 amps. I want to do this fuse inline but was unsure of how to do it. I am going to be running both power wires to the back from the battery. Thanks.
It would be cheaper, it might be easier to find a place to mount it, and you would have a ton of options if you just do two, 3 slot fuse holders...
4
610
My bad, yes, I read them each as having two 4ohm coils. The JBL diagram left a bit to be desired, IMO. ;) And a double yes, thought U was talking...
9
I plan on getting the fuse to run as a front sub/midbass in my kick panels...I've heard they sound good but you definitely wont get mirror shaking...
Sounds like a bad ground or wiring problem on the 12v+ side.
13
RChillin
RChillin
Kansas City
RChillin
Doxquzme
    May 12, 2024
Brendon Jenness
    May 11, 2024
