how should i wire my sub???
tin
I have some questions. im buying a pioneer champion series pro 3500 watt max 100rms. its a 2 ohm each voice coil? positive with positive and negative with negative? and if I decide to buy another one do I have to change how they both are wired? would it be (a negative and positive together and the negative from one voice coil to the amp and the positive from the other voice coil to the amp? again these will be 2 ohm. so for now I will power that 1000 rms sub with a Memphis 500.1 or I also have a one ohm stable autotek 1500 mono block amp. which one is best for my appicatins?
which autotek amp ,the memphis is not 1000 rms ,it's only 500 rms .and yes + to + - to - for 1 ohm.when you get the second sub ,you'll either wire to 2 ohms or get a new amp thats .5 ohm stable
//content.invisioncic.com/y282845/emoticons/wow.gif.23d729408e9177caa2a0ed6a2ba6588e.gif
So you have a dual 2 ohm sub. Here are your options for a single sub:
Here are the 2 sub options (with 2x dual 2 ohm subs):
can I run one wire to each terminal on the sub. for example. instead if bridging it from one terminal to another one can I run 2 wires from the amp and each to coil. is that a better way the bridgeing?
whis is better amp? my 500.1 Memphis? or my 1 ohm stable 1500 autotek?
it is the sm1-1500 autotek street machine... that one is broke so I want to see if is worth fixing. I need it to handle the 2 1000rms champions pro.
thanx for your help
It’s nice having a test bench. That one is nice and clean! I don’t have pics of mine but mine is built all out of wood with carpet top and all...
16
The CT's are nice, That Sundown is a a frik'n beast!
835
2012 Nissan altima SR The trunk not ready to take back seats out I'm happy with the front and rear stage sub stage also I have a Sony DSX M80...
10
708
You can get close with tones, but music signal is all OVER the place in both frequencies and voltages. Like, if you listen to rap, the bass line...
822
tin
tin
oakland
tin
    May 31, 2024
    May 24, 2024
