How many ohms should be entered into the voltage equation for setting gain?
  • 2
hutt132
US
I will be wiring my sub like this:
To set the gain with a multimeter you use this formula to determine what the voltage output should be: Voltage = square root of watts x ohms
Do I put 2ohms or 4ohms in the equation?
Alright sorry this took so long. Here's the update. I tried out all the sets of speakers, the black diamonds did not fit front or back. I think if...
23
4K
5 ch amps can get expensive and most of the sub stage lacks power for a decent mid-sized sub. And end up running hot. Some times its best to look...
11
This is a little more money but well worth it from looking at the reviews. And it's Korean.
13
I wouldnt waste the time or money on OEM speakers to be placed back into any vehicle unless you plan to sale the vehicle and remove the after...
4
With half inch MDF, it's like 4.27cu/ft internally not including sub and port displacement. That's like 3.5 to 3.8cu/ft after displacement. You...
hutt132
hutt132
US
hutt132
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
