how many inlines? and what fuses?
  • 4
cynicz
illinois
Ok im running approximately 16 FT of wiring from my first battery (under the hood) to the first spare in the trunk. Then approx 3ft of wiring from spare 1 to spare 2. then like 2 or 3 ft of wiring from spare 2 to my amp.
Im running knu konceptz 1/0 from the under the hood battery to first spare in the trunk. then the 3ft jumpers will be streetwires 1/0. I am running a AQ3500D.
So I got 1 inline under the hood thats like 150amps, should I put one before the first spare battery? or just after the second spare battery before the amp. i saw AQ recommended 300A fuses but is that high fo a fuse neccesary?
Fuse positive cables where they are prone to damage, as close to the battery. Between front and rear batteries and between battery and amp. 3 total. No need to fuse the jumpers, just take care to prevent any possible shorting.
Fuse per mfr recommendations.
Ok im running approximately 16 FT of wiring from my first battery (under the hood) to the first spare in the trunk. Then approx 3ft of wiring from spare 1 to spare 2. then like 2 or 3 ft of wiring from spare 2 to my amp.Im running knu konceptz 1/0 from the under the hood battery to first spare in the trunk. then the 3ft jumpers will be streetwires 1/0. I am running a AQ3500D.
so you got Knu 0 gauge and you fused it with a 150a fuse? you know your suppose to fuse for the wire?
well I posted here and everyone said 150amp fuse for 1/0guage for the AQ1200D was sufficient now I got a aq3500D and audioque recommends 300amp fuses. So I guess i will upgrade to 300amp fuses. Man this is automatically going to bump me into street5 meca class ughhh haha
Alright sorry this took so long. Here's the update. I tried out all the sets of speakers, the black diamonds did not fit front or back. I think if...
23
4K
5 ch amps can get expensive and most of the sub stage lacks power for a decent mid-sized sub. And end up running hot. Some times its best to look...
11
This is a little more money but well worth it from looking at the reviews. And it's Korean.
13
I wouldnt waste the time or money on OEM speakers to be placed back into any vehicle unless you plan to sale the vehicle and remove the after...
4
With half inch MDF, it's like 4.27cu/ft internally not including sub and port displacement. That's like 3.5 to 3.8cu/ft after displacement. You...
cynicz
cynicz
illinois
cynicz
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
