how many ( amps/rms ) can i run throw 1/0 wire ?
  • 5
ok when you say 300 +/- does that mean if i add what each amp takes like my ppi amp takes a 160 amp fuse, and i just add them up ?
the fuse rating is just incase something goes wrong on an amp, normally an amp will only pull about half of its fuse rating. I meant by +/- give or take a couple of amps.
just to keep things simple you will be fine, like others have said
5 ch amps can get expensive and most of the sub stage lacks power for a decent mid-sized sub. And end up running hot. Some times its best to look...
11
Alright sorry this took so long. Here's the update. I tried out all the sets of speakers, the black diamonds did not fit front or back. I think if...
23
4K
This is a little more money but well worth it from looking at the reviews. And it's Korean.
13
I wouldnt waste the time or money on OEM speakers to be placed back into any vehicle unless you plan to sale the vehicle and remove the after...
4
With half inch MDF, it's like 4.27cu/ft internally not including sub and port displacement. That's like 3.5 to 3.8cu/ft after displacement. You...
big scott
blazin low, and loud
big scott
edgewood, md
Slobalt
