How far can you go on stock alt?
AwesomeStranger
Hey guys, I'm currently running two sa-8 v2's on a apsm-1500. Love the setup, but I might just want more power/different setup sometime soon.
Anyways my 2004 lancer oz rally has a 90 amp alt stock. AT 1/0 big three, brandnew yellowtop under the hood and Knu 4 guage to the amp.
Obviously if I go to say 2-3k rms I'll need 1/2 runs of 1/0, battery(s) in the rear, and possibly a new alt.
Well my question for you guys is, how far on power can I go with a stock 90 amp alt? I found this alt on ebay and it's 180 amps.. Should I have a custom alt made for me?
High Output Alternator Mitsubishi Mirage 1 8L Lancer 2 0L 4CYL 2002 2004 180Amp | eBay
I was thinking either getting 2 batts in the rear and keeping my stock alt, or getting this and yellowtop for the rear.
My future setup will probably consist of a single custom sundown Z 12 v3 with NS2 coils/cone upgrade and a 2.5-3k rms amp.
Ideas?
I run a crescendo bc3500 on 2 dd3512.s with all at 1/0 big 3 deka under the hood stock 125 alt..voltage drop isnt too bad..and i wouldnt buy that alt..i dobt cobsider 180a a ho alt
You don't have a rear battery? 180 amps is a lot better than 90 lol. I guess I just feel limited with 90 amp alt. Yes before you say it I will be having this car for a while, got to pay it off in a few years time so I'm not worried about getting an alt and not being able to sell it later.
Would it be worth my time to go to a junkyard and pull an alt like mine and have some company beef it up?
Yea i got a deka under the hood and a deka in the back..and if your gona.keep the car save up and buy a good al like dc tenney ea mechman .something like that...that rubicon must be a inefficient power hog
About 10 years ago I ran 2 Kickker 800.2's and a 800.4(Class a+b's -2700rms total birthsheets) on a 80a alt, single batt. Was loud as fug. Lights dimmed but thats all it did. Also ran a modded mtx 1501d and the same 4ch, just voltage drops, none to an unsafe level.
Im running an saz3000 and 2-12" custom zv3s, I have a kinetik hc1800 under the hood kinetik hc2000 in the trunk, zero gauge big 3, 2 runs of zero gauge from front batt to rear on a stock 90 amp alt and my volts will drop to 10 at ease at fult tilt ive even seen it drop in the 9s!! Obviously I dont play it like that, but I did order a 200 amp alt that should be here next week. Get the biggest alt you can fit in your car and go with a well known brand!
So I e-mailed Tenny alts and here's the response:
220 amps does abou 140idle
$325 Free powder coating
Lifetime warranty
Takes up to 3 weeks to build this type of unit i have to custom make the stator for high amp
Is there anything wrong with that ebay alt I posted in the OP?
Da*m that's low lol. How do you like the Z v.3's? I'm sorta wanting just one, but depending on funds I might get two..
Check out singer alts, they are said to be good. I have looked into it and he makes a 240amp alt for my 09 lancer(150 idle). So im sure he would make one for your car. He said it only takes a day or 2 to build. Send him a email, he replies quick.
If you're going to have the car for a long time. I would just have one of the great HO alt companies build you one. It'll run around $400, but much more reliability and performance for a car that's going to be around a while. I'd look into DC Power, Excessive Amperage, Ohio Generator, and Singer Alternators.
Agreed and Brand X doesn't exactly have the greatest rep to begin with in the car audio community for a decent product.
4
976
I didn’t want to mess with my daughters EV, so I just made a small stand alone with 6x9s. It’s around 75 watts rms and fairly loud actually. Real...
8
Hello I also have a question I want to buy 160ah lto, i.e. 4 banks but I have a stock alternator of 140 a and a maximum load of 14.9 do you think...
If you are going to replace the HU, then the AC unit is not needed. As to which are good to use, I like the Kenwood Excelon, Sony, Alpine and...
6
718
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
887
AwesomeStranger
AwesomeStranger
Hickory, NC
AwesomeStranger
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
