How big of a flash will Pioneer front USB accept?
Databyter
San Diego
I have a Pioneer DEH-P7200HD with a front end usb port.
It's pretty nice but I am using half a dozen 1 gig flash drives I already had. I'd prefer to use a bigger stick or possibly even a massive flash drive but I can't find any spec's on what the unit will handle.
It has to have the memory to list the files and organize them onto the display etc.
If any of you have used bigger drives with success or know more about this please toss me your experience.
I think it should do well with at least a 30 gig stick, but it would be awesome if I could even put a 80 gig flash drive on shuffle.
I'm holding off buying any new media till I find out about this.
I think any headunit that has a USB port can take up to any size, just the bigger the storage the longer it takes to load, but I have used 100GB Ipods on my kenwood unit without a problem
Pioneer Support basically told me that there is no limit, that it didn't work that way, and that the specs point to USB 2.0 compatability.
However I am still skeptical that this is accurate in real life usage. It's not just the ability for the head unit to list all the files, but also the startup drain in power consumption since some of the memory I am looking at is actually a usb powered HDD that needs several watts of power to run.
Also I've heard that the HDD's need to be formatted in the FAT32 (or less) configuration, not ntfs to be read, which isn't a big problem as long as I could find an HDD that was compact, and had low power requirments.
Ideally I'd like to have it powered seperately and just use the USB for DATA only, but so far I'm not seeing the right set of components.
I should probably just use flash sticks, and probably will, but now I just HAVE to try this just for the experimental purpose.
I'm looking at the 160 GB range at the moment, that would satisfy me, especially if I could make it operate on random within selected folders.
Laptop or "Portable" drives that are charged through a USB2.0 config would work fine, just as well as an i-Pod. From what I read from my 7200, and what my shop that has done all my work has told me; they will only effectively read up to 750 GB. Any drive larger than that you would have to partition it so that it looked like 2 separate drives to the deck. Trust me though a 500 GB or 750 GB drive would hold all of your music, videos and even have space left over to back up most people's PCs. Just make sure your music is in Artist-Album-Song folders like the way i-Tunes manages it and you can easily search for and use a large drive with the Pioneer decks.
Check out Newegg for some flash drives with a fast WRITE speed. I got a Mushkin and love it. Ive went through several of the cheap Best Buy brands. They are the same price or more for a fraction of the write speed and they seem to take a **** if you use em enough lol
Wow, kinda baffled here. Once you get the tune right. You don’t need to mess with it. However, A bad tune you will. You may have different type...
16
I will still find the blame..Bad tool, cheap connectors, junk wire..LOL 🤣 🤣 I didnt have enough B12 this morning is my favorite
23
3K
Yea I don't think I'll be throwing anything like that too it lmao. I think I'll be happy either way I decide to go but I'm just excited thinking...
8
Databyter
Databyter
San Diego
matt_bennett05
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
