High pitched buzz help
  • 2
tonksie93
CarAudio.com Newbie
18
I have a static high pitched buzz when my cars engine is on. My headunit, DSP and both amplifiers all ground straight to the battery (located in the trunk). When i unplug ONE of the RCA’s going into my DSP’s input the buzz stops. But when both RCA’s are connected the buzz is there, when both RCA’s are disconnected the buzz stops too.
I am using the cars OEM headunit and fitting an aftermarket one is not an option. The headunit outputs a low voltage signal through twisted speaker wires, which i have then attached RCA connectors so they can plug into my DSP.
Any ideas?
Any ideas?
 try using actual insulated/protected rca cable rather than a speaker wire in a rca connector
Decibels are a measurement how loud something is...it's not the frequency of hearing...
19
3K
Maybe/maybe not. First it's just a guess, but components can change value with temps and this could be normal. Could also be a sign of a cap on...
You are clipping at the HU, and as stated.. will eventually damage the HU if continued. sounds like you need a little more power as stated. A 2 ch...
306
Use two sets of RCAs. One set for the Front channels and the other for Sub Output and into Rear Input on the amp. Turn off the Rear Filter on the...
5
910
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
763
tonksie93
CarAudio.com Newbie
tonksie93
BassDrop69
Decebal
    Jun 10, 2024
