high amp alt problem...
  • 6
Strecker25
Better than everyone
i installed my motor city reman h/o alt today and upgraded the main cable to 0 gauge, everything looks fine
when the engine is running especially at low rpms the alternator whines like crazy, and will not at higher speeds. What could be a reason for this'? theres no rubbing, the alt spins fine when the belts not attached, and the belt itself is fine also. im stumped?
shitty, i do get a little vibration too..lifetime warranty is on the unit so what do u think send it back? or pop a new bearing in myself?
yeah man, I would send it back. Putting a new bearing in is a pretty decently sized job. Not somthing you wanna fcuk up if you try to do it yourself either.
yea what a pain in my ass, did figure out how much power i freed up just by upgrading my alt to battery cable though, since i got the stocker back in now. im getting constant 13.8-14.4
itll be goin back soon, looks like that lifetime warranty is really helpin already lol
Theyre pretty good on returns and what not..I had a 165amp from them had for a few months and finaly started doing the same thing..sent it in 2 weeks later got it back,but i havent put it back in,think gonna just use it as a back up*I had another 180 alt*
gain set well below "Normal" and base boost is off completely
15
16.6 is way too high. That will destroy an AGM battery. What alternator brand did you use? Sounds like a voltage regulator issue. Are you...
4
Maybe/maybe not. First it's just a guess, but components can change value with temps and this could be normal. Could also be a sign of a cap on...
I am planning out a system for my ‘04 Ram 1500 with the Infinity 7-speaker system. I havnt bought anything yet but I already have a 10in sub from...
You are clipping at the HU, and as stated.. will eventually damage the HU if continued. sounds like you need a little more power as stated. A 2 ch...
327
Strecker25
Strecker25
Rochester, NY
monte_carlo97
