Help
  • 2
PNILLZ
I have a db drive dual 600w max sub box and an okur 1000.1 amp, I have had this same setup for about 2.5 years. Recently the amp had been going into protection mode I checked all the wires, fuses, connections, and for corrosion, but it kept going to protect. I played the amp by itself for a few days and it was fine. Then I connected the subs back and it fucked up again, then I just connected one sub and its been playing fine. Does anyone know what the problem could be?
Got it figured out! Thankfully a friend just found out about KunKonceptz UBT-20 terminal adapters that allow multiple connections to my type 94...
464
Turn the volume completely down and operate ot normally. This is to see if it is the built in amplifier that is shutting down. If the radio does...
That would be a function of the harness, not the HU, I think. Have you looked into a Maestro or iData interface? i would check with crutchfield...
12
531
Dammned good speakers. Just pass up the CL series,and you will be pleased with CDT speakers. I still enjoy all mine. Polk MM series and Infinity...
4
562
PNILLZ
PNILLZ
New Jersey
Side Show
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
