help with wiring problems
  • 3
dray67
20
Yuma,AZ
Ok I've tried everything and stereo shops all tell me different. I have 2 12 kicker l7 4ohm speakers wired to 1ohm to a rockford fosgate t1500 ,I have a red top optima as primary battery with 0 gauge ran to trunk battery, then 4 gauge ran to amp. I grounded trunk battery with 0 gauge and my amp is grounded to trunk battery with 4 gauge. My alternator is 130amp and has 4 gauge to primary battery. Now sometimes amp gets hot and cuts out, other times mybattery light comes on so I turn it down,now the question is, do I have a wiring problem somewhere??
The t1500 has 4 gauge, and battery is good, I found a better ground and is currently working at 4ohms, now the question is, will my l7s sound better in a custom box, because it doesnt sound as good as it should. Will a custom box make a big difference and can it be done for a 2002 dodge intrepid?
Based off GM pickups of the same year (and that was GM), It SHOULD just be for the vehicle sounds that play through your stereo, such as the door...
Thanks for the input. Much appreciated. The dsp is an afterthought. I haven't installed anything yet but I put a budget system together. I already...
665
In a case like In a case like yours I would rather recommend tactile transducers. They are like woofers without the cone section that are...
7
Your image doesn't really show anything. That could be 3 different head units for all we know, but I think it's 2 different add-ons. It sounds...
dray67
dray67
Yuma,AZ
dray67
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
