help with port length
  • 3
Bomtillington
Hi guys I have a 6.2 cube box for two 12 inch l7 the port was going to be 3 inch wide and 13 inches tall but what do I do for length I don't trust the calculators so I'm asking you guys for help and is 3 inches wide enough or do I have to go wider any help is appreciated!
What are the dimensions of the box? I can plug it in my box calculator for you
Also you'll want a lot more port area
fixed it
5.5 wide port, 27 in long gives you 33hz with optimal port area with 4.8 cubes of net volume left
Can I put both speakers on on side and the port on the other?
That would reduce your output significantly. You want your subs and port on the same face or faces right next to each other. For example: subs back port back; subs back port side; subs up port back; etc.
If you're talking about having your subs face back and the port fire out the side, yes that would work just fine. Just make sure there's enough room inside the box to mount your subs or you'll be forced to invert them
or if I wanted port length of 26 inches what would that tune it too this way I can center it and no have to make an l shape
26 inches wouldn't work because there would only be a 1 inch gap at the back. And yes, you can have the port against the side of the box (like you said on the right side with the subs on the left) and that will work just fine and be easier to build
About the longest you could go without bending the port would be 21 inches and that would give you 35Hz tuning
I'd have the internal port end 7" away from the back wall and just roundover that corner. That back (rounded) wall should effectively extend the...
None so far, there was a factory 8 inch subwoofer that I took out for a pass through, I'm definitely going to have to get some sound deadening...
10
Yes. I do not fully understand the question, but if the manufacturer suggests such a big port, it is probably because it has a high QTS. If it...
Got it figured out! Thankfully a friend just found out about KunKonceptz UBT-20 terminal adapters that allow multiple connections to my type 94...
477
Turn the volume completely down and operate ot normally. This is to see if it is the built in amplifier that is shutting down. If the radio does...
Bomtillington
Bomtillington
Rhode island
SounDrive
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
