Help with dvc sub wiring
  • 2
bigman357
CarAudio.com Newbie
MN
I have a lanzar vibe 800 watt amp with four channels, the lowest impedance is 2 ohm, is bridgeable at 4 ohms. The subs are 2 4ohm dvc IX-12s. I am looking for the best sound quality and efficiency. Any help appreciated!
Not the best matchup. You'll have to run each sub in series at 8 ohms. 4 channels are like the worst way to power a sub. i'd strongly recommend switching to a mono block
Hello I'm happy to have came across this forum as I'm hoping someone will help with this little bit of confusion I'm having and maybe save me some...
Sure, 600 volts, yep. If you’re trying to launch the subwoofer cones to the moon! And, that’s if they don’t just vaporize first!
34
4K
Turn the volume completely down and operate ot normally. This is to see if it is the built in amplifier that is shutting down. If the radio does...
That would be a function of the harness, not the HU, I think. Have you looked into a Maestro or iData interface? i would check with crutchfield...
12
379
Dammned good speakers. Just pass up the CL series,and you will be pleased with CDT speakers. I still enjoy all mine. Polk MM series and Infinity...
4
324
bigman357
CarAudio.com Newbie
bigman357
MN
Buck
winkychevelle
    May 24, 2024
1aespinoza
    May 23, 2024
