Help with big 3 upgrade.
I have a bunch of 0 gauge wire, pm me your zip and I'll let you know a price. I used some install bay but it was not that good, worked for my build 6 15's. I have a couple of different kinds. All you would need to do is take a string, use that as a template for the measurements. I am about to run all new wire so let me know.
Ok I didn't really think it mattered because ground is ground just wanted to be. Sure. So I'll do alt to bat, batt ground to alternator mount, and...
Got it figured out! Thankfully a friend just found out about KunKonceptz UBT-20 terminal adapters that allow multiple connections to my type 94...
552
Turn the volume completely down and operate ot normally. This is to see if it is the built in amplifier that is shutting down. If the radio does...
That would be a function of the harness, not the HU, I think. Have you looked into a Maestro or iData interface? i would check with crutchfield...
12
563
Mr.meyhem
Mr.meyhem
Cold as F***, MN
accuab
Decebal
    Jun 10, 2024
