Help wiring amp & head unit to leisure battery
  • 1
Tom Keyte
Hi, thanks in advance for any help. I've added a leisure battery to my van, using the wiring in this video: https://youtu.be/oOQHe_cZtI4?t=1044
I have this amp: https://www.caraudiocentre.co.uk/product_m-pioneer-gm-d8704_p-41014.htm and this head unit: https://www.pioneer-car.eu/uk/products/deh-s3000bt
I'm assuming the head unit will be fine if I wire it in to the fuse block (this one: https://www.amazon.co.uk/gp/product/B01IVRC9RA/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1).
Should I re-wire the permanent or ignition switched terminal from the back of the head unit to the fuse block.
And my main question...
For the amp, Should I be connecting that via 16mm cable straight to the battery (or to the isolator switch in this case) and does it need its own fuse.
Thanks
Tom
In a case like In a case like yours I would rather recommend tactile transducers. They are like woofers without the cone section that are...
987
No not in this situation.PM sent for proper use of the Y splitters for this situation
34
5K
problem was the LOC burnt out when I had touched cables. got a new LOC and now all is working. have to get the gain right, lights flickering with...
well ****, thanks anyways. Will leave the thread open just in case someone knows anything :)
Tom Keyte
Tom Keyte
Tom Keyte
    May 31, 2024
    May 24, 2024
