HELP!!! Weird sound from speakers when using 3Sixty.2!!!!
  • 4
Well if everything is fine without the unit, then it seems that the unit is causing the noise.
If ground/power, voltage, all the wiring is correct, and the install of the dsp is correct, there shouldn't be a noise.
Brand new things can be defective though. I order some speakers a month ago and they came in defective. It happens.
maybe someone more familiar with dsp's can give you some more info though.
One could also possibly try to put a filter on the power input and see if you can get rid of it that way.
I miss hawaii //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
Got it figured out! Thankfully a friend just found out about KunKonceptz UBT-20 terminal adapters that allow multiple connections to my type 94...
470
Turn the volume completely down and operate ot normally. This is to see if it is the built in amplifier that is shutting down. If the radio does...
That would be a function of the harness, not the HU, I think. Have you looked into a Maestro or iData interface? i would check with crutchfield...
12
532
Dammned good speakers. Just pass up the CL series,and you will be pleased with CDT speakers. I still enjoy all mine. Polk MM series and Infinity...
4
563
DropDownLowYota
DropDownLowYota
Honolulu, Hawaii, United States
CrossoverOre
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
