Help! Shifted motor!
  • 3
I'm very scared this motor is shifted! Please let me know or if it will get worse or if its fine! Any help will be appreciated!
[/img]
Also it's no bigger than 1mm
That's not what shifts, it genrally the pole and or top plate, I think you're fine unless it rubbing them I would say there's damage to the coil/former.
My brand new zv4 magnets are not perfectly stacked either, I think it's fine I would check the measurement around the gap and see if it's consistent.
Got it figured out! Thankfully a friend just found out about KunKonceptz UBT-20 terminal adapters that allow multiple connections to my type 94...
182
Turn the volume completely down and operate ot normally. This is to see if it is the built in amplifier that is shutting down. If the radio does...
That would be a function of the harness, not the HU, I think. Have you looked into a Maestro or iData interface? i would check with crutchfield...
12
459
Dammned good speakers. Just pass up the CL series,and you will be pleased with CDT speakers. I still enjoy all mine. Polk MM series and Infinity...
4
446
Neily_OB_24
Bettendorf
Slo_Ride
maylar
    Jun 2, 2024
Doxquzme
    Jun 1, 2024
