help settin up massive audio system
  • 2
halodenied
Ok I have the following
2 - p1500.1 amps
2- 800.4 amps
4- cw12" stg2 subs
4-6.5" massives for my doors
4-2" tweeters
4 massive crossovers
This will all go in my blazer . The sub box will be 3/4 plywood wrapped wit fiberglass about 10 cubic feet . How big should my ports be? I'm thinking L port . Or should I run 2 subs one off each p1500 any help would be great !
Got it figured out! Thankfully a friend just found out about KunKonceptz UBT-20 terminal adapters that allow multiple connections to my type 94...
171
Turn the volume completely down and operate ot normally. This is to see if it is the built in amplifier that is shutting down. If the radio does...
That would be a function of the harness, not the HU, I think. Have you looked into a Maestro or iData interface? i would check with crutchfield...
12
456
Dammned good speakers. Just pass up the CL series,and you will be pleased with CDT speakers. I still enjoy all mine. Polk MM series and Infinity...
4
433
halodenied
halodenied
kewaunee, WI.
Imtjnotu
maylar
    Jun 2, 2024
Doxquzme
    Jun 1, 2024
