help problems with my amps
  • 4
mx591
hi i am having some weird problems with my amps and deck i just put in 2 new 15' woofers in my truck and a new d class amp and a nice dvd head unit about 2 mouths ago. it was all working fine for a wile but all of a sudden my d class amp started to go into protect mode and my other amp that powers my door seekers was fading as i turned it up but once you turn it back down to a point it is all fine but dose it again when you turn it up. so i replaced my head unit with a spare and everything was fine for about a hr then the problem returned and i do have a good ground. any one have any ideas? thanks!
I'm guessing the issue is the d class amp. It's fake. Mix a fake d class amp with 5 gauge power and ground wires and you've got a situation that can't be corrected. Throw it out. Try again.
Based off GM pickups of the same year (and that was GM), It SHOULD just be for the vehicle sounds that play through your stereo, such as the door...
Using Sky High copper OFC wiring and Stinger 8000 series rcas. The US Acoustics usx4085 is rated at 85X4 @ 12.9 volts and proably close to 100w X...
187
626
mx591
mx591
hooksett NH
daboyfrumdabx
chillin
    Jun 14, 2024
