Help needed with enclosure design
  • 3
sweety
Hi all:) I'm about to build my first box as the box I bought i've found out is a bit to small at 28L. The sub I've got is a JBL GT3-12 which i've found on the net should have either a 40L sealed or 50L ported but thought I would ask you guy's the spec's for the sub are as follows
JBL GT3-12 12"
RMS Power Handling:225W
Peak Power:1800W
Voice-Coil Diameter:50mm
Mounting Depth:155mm
Qes:0.6
Qms:5.53
Qts:0.54
Vas:100.45 ltr
Fs:28Hz
Pe:225watt rms
Frequency Response:35Hz - 3kHz
Sensitivity:89dB
Impedance:4 Ohms
At the minute I have a wedge shaped box which fits perfectly against the back seat so would like the new box to be of the same shape. The room I have for the box to take up is 41" wide, 16.5" high & 12-13.3" depth can put up the size of the box I have at the minute if it helps:rolleyes: Ideally I would like a ported box if it's possible but have know idea on size of port(s) to use. I listen mainly to dance music & rock if that helps.
I would be most grateful with any help & possible design with measurement if you can
Many thank
Just had play with an online enclosure calculator & have worked out a enclosure measuring 30" wide, 14" high, 12" deep at the bottom & 8.5" at the top will give me a volume of 1.804ft3 or 51.082litres but this is not including the displacement of the sub or port which I didn't add as unsure how to work it out. Does this sound about the right size box I need ? Still have no idea on what size/length of port that would be needed:confused:
With that size box the port is going to be long, so you will loose even more volume for the port
Its going to be close, not impossible but I think do-able
Thanks for the input guy's, had a chat with a lad on this side of the pond & he thinks for the set up i've got that a sealed box would probably would be the best option for my sub but said build a 50L box & see how that sounds then poss partly fill the box with polystyrene & see how that sounds:confused:wondering if I should go for a 40L box & if needed fibre fill it:confused:
Well after a bit more thought & playing about with these online calculators I've come up with a box size of about 50L as mentioned above & from what I can gather a port 2.5" x 4.75" should tune the box to 34Hz:rolleyes: As I listen to mainly dance music would the be about the right frequency to tune the box to ? & would it be possible to fit 2 ports 1 either end of the box on the top & just 1/2 the length of them
Got it figured out! Thankfully a friend just found out about KunKonceptz UBT-20 terminal adapters that allow multiple connections to my type 94...
160
Turn the volume completely down and operate ot normally. This is to see if it is the built in amplifier that is shutting down. If the radio does...
Thanks for the input. Much appreciated. The dsp is an afterthought. I haven't installed anything yet but I put a budget system together. I already...
633
Absolutely. I am always learning and think it's probably impossible to stop learning. I appreciate the advice and don't doubt for a second the...
56
4K
sweety
sweety
Northumberland, UK
sweety
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
