Help needed for enclosure size
  • 2
Can anyone tell me what they come up with for the cubic feet of this enclosure? I calculate the inside to be 8.8 cu ft. Is this correct, or close to what it is? All measurements are inside dimensions. Please disregard the second attachment, it is incorrect, and I could not figure out how to delete it.
8.45 cubes. The smaller angle piece that's labeled as 10.25 should be 9.25 with your updated measurements. Surface area from the side is 362.67 in^2
Thank you for correcting me. I went out, and measured again, and indeed, the measurement is 9.25......I have no idea where I got 10.25, in the drawing. Now, I know what the internal size of my enclosure actually is. Thanks again.
Got it figured out! Thankfully a friend just found out about KunKonceptz UBT-20 terminal adapters that allow multiple connections to my type 94...
525
Turn the volume completely down and operate ot normally. This is to see if it is the built in amplifier that is shutting down. If the radio does...
Thanks for the input. Much appreciated. The dsp is an afterthought. I haven't installed anything yet but I put a budget system together. I already...
679
Absolutely. I am always learning and think it's probably impossible to stop learning. I appreciate the advice and don't doubt for a second the...
56
5K
bgt2u
bgt2u
Ocala florida
bgt2u
